So I was building my first computer, the parts are as follows:
Ultra Aluminux (Something like that) Aluminum case (from an old build)
Ultra 550 Watt Modular PSU (From an old build)
Gigabyte GA Z68X UD3H B3 Mobo
Intel i7 2600K
Corsair Vengeance 8GB RAM kit (2x4gb)
EVGA GTX550Ti
Random LG SATA2 DVD drive (from an old build)
Seagate 7200RPM 750GB HDD (From an old build)
As I was building the computer, I did have some trouble getting the motherboard into the chassis, (i checked it out and it doesn't have any visible damage) and it was bent slightly to get the CPU fan in place, but nothing extensive to my knowledge. On the first attempt to run it, everything went quite smoothly, all the Phase LEDs lit up red on bootup, though the CPU fan didn't start running until a couple of second after the *beep* from the mobo, and until then it just kind of stuttered a little. But after about halfway through Windows installation, it cut out and restarted itself. I found out that the PSU fan was dead (this is an old PSU from an old build) so I jury-rigged one of the case fans to the intake of the PSU, so now the PSU is cool to the touch. However even now it still randomly dies, all the fans stop and it resets itself, could this still be the PSU? I'm quite sure it's not overheating.
Also, after installing Windows 7 Ultimate x64, everything appears to install successfully, then it will go to the desktop for one second, then log off and shut off properly, then it will restart, go to the "Loading Operating System" screen, then it will restart itself, and just go into a loop from there on until I reinstall Windows, at which point it installs properly and does the same thing again. However when it restarts this time, the fans stay running, it seems that just the Mobo restarts.
Any help? Sorry for the long post I just wanted to give all the info I could. I think the full resets are related to the PSU being more damaged than I can see, but I have no idea about the resets where the fans keep spinning? Could it be the Mobo? Do I need drivers? Or a bad HDD is also possible?
Any help would be greatly appreciated!
Kewin
*EDIT* I wasn't getting any video out of the EVGA graphics card when trying to install Windows, so I'm using onboard graphics for now.
Intel i7 2600K
EVGA GTX550Ti
Kewin
