This will be my first build, what do you think about this set up? Is there anything that you see that is incompatible? Will it work out? I want to have something that can grow with our needs.
http://www.newegg.com/Product/Produ...scription=-+Intel+Core+2+Quad+Q6600&x=13&y=33
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227199
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130319
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159055
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150083
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133047
http://www.newegg.com/Product/Produ...=0&Description=EVGA+nForce+680i+SLI&x=20&y=33
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009094
Thanks. I don't want to spend more than $1100 on a complete system.
