First Gaming Build Help!
Quad-core isn't exactly a technology "required" to run things as compared to say 64-bit processors. While quad-core may be more "future ready", dual or tri cores should be just fine. In the end, for gaming, much of the performance is based on the video card anyway.
u sure cause people say quad core is better for future purposes!
Can't fit it within your budget. It is already slightly over CAD$ 700 with tri-core
Curently Phenom II x3 720 ($170) + Mobo ($90) = $260
If you go for Quad-core, the best one will be Phenom IIx4 955 ($220) as it is on offer
The cheapest decent quad core is Q8200 ($180) + Gigabyte GA-P43-ES3G ($90). However, since intel will have new line of CPU with new socket come out next month, it is not worth investing on LGA 775.
Have a look on this article, it's up to you to decide what to get.
http://www.tomshardware.com/reviews/cpu-cores-performance,2373.html
GIGABYTE GA-MA785GMT-UD2H AM3 AMD 785G HDMI Micro ATX AMD Motherboard - Retail
DDR3 1800+ (OC), HD4200 DirectX10.1 & 2 oz Copper PCB
Is the better board.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128397
89.99
or
ASUS M4A785TD-V EVO AM3 AMD 785G HDMI ATX AMD Motherboard - Retail
Xtreme Design w/ GPU NOS, DX10.1, DDR3 1800 OC
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131398
99.99
basically the 785G on an am3 platform with ddr3 is better than the 770 and 790GX, the FX is a different story
