hi there this is my first build and i'm hoping it would last a long time. as a 16 year old in Ireland income is non existent but i am on about a 600 € budget (about 450-500£ or i think its 850$) so i've come up with some parts but i don't want my expectations to come up short as this is a do or die decision with money. this machine will be mostly used for rts gaming ( C&C 4 upcoming stronghold 3 maybe some graphic intensive games not sure ) this machine also must last a long time and perform in this time
so here are wat ive been looking at :
GPU: http://www.overclockers.co.uk/showproduct.php?prodid=GX-099-MS
MoBo, memory and CPU: http://www.overclockers.co.uk/showproduct.php?prodid=BU-042-OE
Case: http://www.overclockers.co.uk/showproduct.php?prodid=CA-017-OP&tool=3
HDD: http://www.overclockers.co.uk/showproduct.php?prodid=HD-130-SA&groupid=701&catid=14&subcat=1279
wifi: http://www.overclockers.co.uk/showproduct.php?prodid=NW-014-OK&groupid=46&catid=1597&subcat=1622
CD drive: http://www.overclockers.co.uk/productlist.php?groupid=701&catid=10&sortby=priceAsc
not sure whether to get psu or would the psu with case be sufficient?
dont need monitor and can get cheap keyboard + mouse somewhere but are these good parts for a good rig?
also does any1 kno cheap places to get windows? im not bothered about which version.... i do however hav a machine that was bought from pc world a couple of years ago with vista but i dont think it came with a cd ( or should it have?) is there a way to get the OS from this to my new machine? (i kno it may sound stupid and i think i kno the answer but i needed to be sure about all possibilites )
Thanks for the help
Sher
Thanks for the help
Sher
