First PC Build
ok...i put in the ocz. Is it better anyway?
How does this look?
Part Cost Company
CPU: AMD Athlon 64 3200+ 939 $255.00 msy.com.au
HDD: Seagate Barracuda 120Gb 7200 8Mb cache SATA Hard Disk $105.00 msy.com.au
VGA: Leadtek 6600GT 128MB SLI $270.00 msy.com.au
Ram: OCZ EL DDR PC4000 Dual Channel Gold VX $379.00 pccasegear.com.au
Motherboard: DFI LanParty UT nF4 ULTRA D $215.00 pccasegear.com.au
Case: R201 Case $129.00 pccasegear.com.au
Keyboard: Logitech Elite $54.00 centre.net.au
Mouse: Logitech MX-518 $70.00 citysoftware.com.au
Monitor: LCD-BenQ-17" FP71E+ Silver 8ms $330.00 custo.com.au
DVD: NEC 3520A ND-3520A $103.00 scorptec.com.au
Floppy: 1.44Mb Floppy Disk Drive $16.10 Centre Com
Speakers: LOGITECH Z-640 $99.00 cworld.com.au
Total: $2025.10
Hehe the ram is no doubt (IMO) superior but you're gonna have to push it pretty hard to get the performance (just like the other ram mind you). :) (make sure you have active cooling on the ram)
man i live in adelaide and thats a pretty good buy mine comp cost 3000 aus but i got the 3500 and same graphics card but mx1000 mouse and logitech 5300e speakers and ummm printer so yeh gd setup thogh man
There is already a 90mm fan on the side panel...but I don't know if I still need to buy another fan. If I buy another fan where will it go?
There's a front(intake) 120mm, rear(exhaust) 120mm, and a side(intake) 90mm.
Any help would be appreciated.
From this pic I think it's at the ram, but can you confirm?
ok...could you recommend me a brand?
Get a cheapo $5 80mm fan and hang it over the memory :) Although its active memory cooling i would not trust the Thermaltake active memory cooling to cool your ram enough) ... any standard fan should be decent
Both although it overlaps CPU more.
So I don't need to buy an extra fan?
Probably not ... buy the case as it is and then if you need/want, buy the fan separately :)
Glad to help but just a comment ... i know you Aussies pay a bit more than us 'nucks but you may want to hunt around for a lower price on that mobo still :)
the dfi mobo only sells for 215 minimum...seen nothing cheaper. Like the ipod here. Every shop sells it at the same price.
