Good fan power?
If you're not concerned about noise then just plug it right into the PSU. If you are you can plug it into the motherboard and control it through the BIOS. You may be able to find a program to control it also if you go through the motherboard. I don't know of any though.
The above is all assuming this is a case fan and not your CPU fan/heatsink. That will plug right into the motherboard.
Yeah, those fans will be plugged directly into the power supply. You can buy a fan controller if you're concerned by the noise.
