geelongcats29
PLZZZ Help.
I recently gotta a new computer and installed Windows 98 the the XP Pro Upgrade. I did not have a valid CD Key because I used the same one as this my old computer so i bought XP Home. Before I installed XP home I had 2 partitions of my Hard Drive C: (Which was 1.99GB) and E: (Which was about 75Gb). So I decided i will wip it all off and start from scratch so I installed Windows 98 and then I was planning to install Windows XP Home...
So I installed Windows 98 and was about to Install the XP home upgrade and when I went to install it it said that I did not have enough space need to install it.so i checked the size of my main hard drive and it was only 1.99GB which was exacly what it was b4 I intsalled Windows 98 but there was only the 1.99GB Partition not the main 75gb one plzzz help me I cant put any thing on my computer because there is not enough space.
PLZZZ Help.
PLZZZ Help.
