Impr3ssiv3
First you will want to have the system up and running to avoid any configuration issues and improper hardware detection when installing XP. Once you have a smooth running system going you should be able to add the 40gb in and easily copy your data and files freely from it. If for some reason you find that the drive is inaccessible one easy fix for that is to boot a Linux Live for cd distro. The one rated the easiest to use is Knoppix Live for cd. You simply need a software for burning iso images to cd-rs. The image is about 500mb in size roughly speaking.
The live distros take a little bit to get used to. But a distro like Knoppix is a good live version to have around for accessing drives when something prevents normal access(missing or corrupted mbr info etc.). With a standard ide controller on the board there you should be able to copy without problems. But if something comes up try a live distro or slave the drive in a working case for temporary transfer/storage. Knoppix has a slight difference in copy commands. But nothing major. In fact I have to refamiliarize myself again. But I keep a distro onhand anyway since it can access Fat16, Fat32, and NTFS partitions just as easy as if they were Linux types.
ok
i have another idea
i am on my moms computer and she has an IDE HDD. Could i hook up my drive as a slave to her HDD and then copy files that way. and then when i get past the whole installing OS on the SATA just copy the file back over a home network i setup
