pcspecialist
Alright, I have sort of an issue here and I'll to try to explain it as detailed as possible. First off, I have a Sound Blaster Live! 24 bit in my desktop computer, hooked up to 5.1 surround sound using black, green, and orange cables. I have one plug free, which is the blue one used for Line In and Microphone. I also have a TV Tuner. The TV Tuner has an Audio Out, or Line Out, and that is plugged into the Line In (or microphone, the blue cable) of the Sound Blaster Live 24 Bit. Now, I bought a DVD Recorder a little while ago because I wanted to record gameplay for some games I have like Madden, NBA, and whatnot. So, my sound card has a video in (the yellow plug), and that's hooked up to my DVD Recorder, so when I change the source from my TV Tuner to Video (Not TV), it displays my DVD Recorder. I also have S-video hooked up from my 6600GT to my DVD Recorder. All that works perfectly fine, the video that is. My only problem is the audio. I have another sound card that's onboard. Realtec makes it. That has 3 plugs: green, pink, and orange. My question basically was.. if I was playing music or playing a game or whatever the case may be, how would I get my computers sound to be recorded onto the DVD Recorder. I've tried so many things and nothing worked, so ANY help would be greatly appreciated.
Thanks
Thanks
