[HELP] IBM Server Hard Drisk Problem
Exclikers
Hello Everyone..
i have a problem on my server... my problem just send me a big monster server with 40klg.. and now i've try to set it up..
The Server has a 2 SATA hard drive on it.. 10,000RPM. 80GB Each..
the two hard drive detects on BIOS when i enter the setup. but when i tried to install Windows Server 2003 on it.. the setup says.. setup was unable to continue setup because no hard disk on your system was detected,, something like that..
so it means the setup dont detect my hard drive.. but the bios yes..
so what is the problem? i try also to run with only one drive. but same problem..
Any solution to this?
Thank you very much
brian
You're sure their not SCSI drives?
If theyre SATA then see if there is a setting in the BIOS that has a setting called ACHI and Compatibility. if there is that setting change it to compatibility and it should work.
