help! ie problems
whipador
OK, things just keep going from bad to worse. I am having major, but weird issues with internet stuff. Here are some of the symptoms and some of the things I've tried:
Can not edit the pages on my website (website through microsoft office live) -- however, I can do so from another computer (at my neighbor's -- using same ISP).
I can request a map on mapquest but it doesn't display (although it thinks it does)
My ISP is AT&T and they use Yahoo! as their email. If I try to access email through AT&T-Yahoo, some emails open just fine, other emails take forever to open, and others actually lock internet explorer and I have to end ie by using task manager (and even then it takes multiple attempts).
Sometimes internet explorer just locks up.
This all seemed to start several months ago, but I can't remember anything that changed at that time. It started just taking longer than expected to open emails and has gotten worse from there (has also gotten worse each time AT&T tried to "help" me.)
Things I have tried that have not helped:
Updated JAVA to latest version
Reinstalled IE 7.0
Went back to IE 6.0
Installed Mozilla Firefox and tried that
Reduced all the security levels to below default, disabled anti-phishing, disabled pop-up blocker (currently now set back to default)
disabled IE add-ons
AT&T had me go into advanced internet options and change some things but it didn't help.
I use SpySweeper anti-virus and anti-spyware religiously.
I have also run AT&T supplied anti-spyware (don't know who makes it)
I did set up Outlook and have it set up to get the Yahoo emails. This works fine, however I have yet to figure out how to have it use my alternate email addresses (i.e. I have email addresses that I use for different purposes, outlook always assumes that I want to use my sbcglobal.net email).
My System:
Windows XP Service Pack 2 (fully updated to latest versions)
Internet Explorer 7.0.5730.13
Java Plug-In 1.6.0_05
AT&T DSL
Any ideas?
Thanks for your help.
Jane
did you try to clear the interent cache? tools->internet options->browsing history->delete->delete the files, cookies and history min you can delete all if you want but not nessesory
Cache was deleted
Yes the cache has been deleted numerous times. (along with temp files, cookies, history, etc.)
Yeah if I were you I would use Firefox. IE gets infected very fast and easy. Firefox also has way more options that you cant do with IE.
