liquidmonkey
ok, i've built a new rig that has a ASUS P6T WS PRO mobo, no cd-burner and one SATA HDD. plus other stuff but its not relevant here.
i'm trying to install winVISTA ULTIMATE using a KINGSTON TRAVELER 16gig usb stick and have tried the following....
googling and reading 40+ articles.
formatting the USB stick using the HP tool (this is done on my winXP Pro SP3 machine)
formatted to both FAT32 and NTFS (at different times to test it)
then i did this...
# Here i am assuming DVD drive as G and Pendrive as I.(Change it accordingly).
# Now type G:CD BOOT
# Now type this command BOOTSECT.EXE/NT60 I: to update your USB drive with bootmgr code.
then i did this...
followed by copying the Vista DVD content to the USB stick with this: xcopy d:\*.* /s/e/f e:\.
have tried using the USB stick on each of the 10 usb drives on my mobo, but no go.
i CAN get into BIOS and did change the boot order to the KINGSTON TRAVELLER.
the ERROR MESSAGE is... insert a boot device and hit any key...or something along those lines.
my info has come from these main articles...
http://www.computingunleashed.com/2008/10/install-windows-vista-from-pendrivehow.html
http://www.computingunleashed.com/2009/01/install-windows-7-or-windows-vista-from.html
http://www.everythingusb.com/vista_flash_drive_12025.html
is anyone can help out at all, i'd be VERY APPRECIATIVE
totally want to use my new rig
ps, i noticed that the USB STICK partition is NOT ACTIVE and unfortunately i can't mark it as ACTIVE in the computer manager. could this be an issue???
then i did this...
then i did this...
