Help me build a computer, or wait for Haswell?
This is what I was looking at for now while perusing newegg. Feel free to suggest changes, preferably with explanations as to why since I'm always open to learning. :)
Corsair Obsidian Series 800D
Intel Core i5-3570K IB
GIGABYTE GA-Z77X
CORSAIR HX850 850W
Sapphire Radeon HD7970
Corsair Dominator Platinum 16 gb (2x8gb)
Crucial M4 128GB SATA III
WD CB 2TB HDD
CORSAIR Hydro Series H100
LG Blu-ray burner
Subtotal: $1,878.90
Is there a CD/DVD/Blu-ray combo burner?
Chrissy
If you have access to this store, this is the I7 for only about 10 dollars more than the I5.
http://www.microcenter.com/single_product_results.aspx?sku=425405
Maybe next year after Haswell's been out for a while I can think about upgrading.
You will mostly have to upgrade your motherboard too, if you will be getting Haswell, as it is rumored to be using 1150 socket H87/Z87 chipset.
