Help me connect my cable modem to wifi router
pikachu
I have this cable modem
http://217.26.67.168/uploads/3/2/3261904/epc21003.png
And I bought this router
http://img.techpowerup.org/130307/Capture021.jpg
It's router + adsl, so it should work.
I connected enthernet cable from cable modem to router, than lan cable from router to pc.
Now, internet works on pc, and on laptop it shows there is a wireless connection, I connect and everything is good, but internet doesn't work on laptop or my phone or any other device I use to connect to that wireless connection.
Also, I cannot enter 192.168.1.1 on my pc when both cables are connected (The one from cable modem and the one that goes from router to pc), but when I unplug the one that goes from cable modem, I can access admin panel.
Any solution ?
johnb35
Administrator
You will need to return the adsl modem/router and get a plain router. It won't work with what you got.
