help me with these parts?
thanchetmy
i am planning to play games, watching hd movie, and download stuffs, akso playing with graphic software like photoshop and stuffs like that, please give me a suggestion? which case i choose is compatible with my mainboard? any correction should be made?
my budget is limited to no more than $1,200.
thank you:D:D
Intel Core2 Quad Q9400 2.66GHz 6MB L2 Cache LGA 775 95W Quad-Core Processor - Retail
Thermaltake CL-P0114 120mm CPU Cooler - Retail
http://www.shopping.com/xPO-Intel-CORE-2-QUAD-Q9400-2-66GHz-6MB-1333FSB-LGA775-Quad-Core
ASUS P5Q-E LGA 775 Intel P45 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131296
Apevia X-Discovery Black ATX Mid-Tower Case with Clear Side
or
NZXT Apollo Black SECC Steel Chassis ATX Mid Tower Computer Case - Retail
OCZ OCZ2FXE12004GK DDR2 PC2-9600 1200 MHz Flex EX XLC 4GB Dual Channel Memory
http://www.amazon.com/OCZ-OCZ2FXE12004GK-PC2-9600-Channel-Memory/dp/B001O9VIBQ
SPARKLE SX98GP1024D3-NM GeForce 9800 GTX+ 1GB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814187056
SAMSUNG Spinpoint F1 HD103UJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
COOLMAX CTI-700B 700W ATX12V SLI Ready CrossFire Ready Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817159085
PowerUp GEN-9010 Internal All-in-One Flash Card Reader - 2.0 USB Port, Black/White
They are compatible, however, personally would change hardware as follow.
Intel Core 2 Quad Q9550
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115041
POWERCOLOR AX4870 1GBD5-PPH Radeon HD 4870 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814131120
I don't know if you really need 1GB GDDR5 RAM, I suggest a cheaper 512MB version if you don't have big screen.
GIGABYTE GA-EP45-UD3P
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128358
or ASUS P5Q Pro
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131299
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model F2-8500CL5D-4GBPI-B - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231246
PC Power & Cooling S75CF 750W EPS12V SLI NVIDIA SLI Certified (Dual 8800 GTX and below) CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817341011
Case: NZXT Apollo, based on ppl reviews...
dude go with daisys build, its better than yours!
but should you decided to go against our word, your mobo supports anything from ddr2 1200 and below (in ddr2, of course)
thank you everyone, i will try all your helps now, thank for the tip Elimin8or, i didn't know that ddr2 1200 mean that it support 1200 and lower lol i thought that is the only speed, lol now i know, thank you all
