Ocean Spray
1) How do I know if a motherboard/video card are compatible? Someone told me the 2.0x16 video card will only work with a 2.0x16 motherboard and I'm not sure if that's true.
2) Is a GiGabyte z68x ud3h for $110 a better buy, or is z77x ud3h for $150 the better buy?
3) What differentiates a computer case from another?
4) AMD, MSIS, Sapphire. Which video card brand is better or are they pretty much all the same?
5) Is AMD FX 6100 for $120 better than i5 2500k for $150? How does FX 6100 fare against i5 2500k in terms of performance?
