Help on front panel please
TaliTheTiger
Hi all, I’m wondering if you can help me with this front panel please. I’ve tried loads of different pics online…. But to no avail. The computer won’t restart. Thank youF3271D47-73D6-4CE3-BAAC-E859FCE518F1.jpeg
What model of computer do you have? Gonna need to know that to figure out what the pinout of that is. A normal Fpanel for a custom built pc is 20 pins, that one is 14. Possible the far bottom pin is broke off?
It appears to be a Lenovo M92P motherboard. I’ve looked at loads of images online but not getting it turned on again, as of yet. It’s 13 pins. It’s the led, hdd, pwr and reset leads!
You can bridge two pins together at a time to see which is power on, and then work your way backwards from there using the LEDs to test further ones.
