Hello to all,
OK basically I am having wireless internet connection problems. I am using a Belkin 54g, the connection is found and connects, but web pages do not display. It is not the router itself as this also happens when I tried a different one. Connecting through a modem works perfectly fine. The DHCP has been checked and is on, I have reset the router settings and it makes no difference. I then thought it may be a DNS problem, I have flushed it using command prompt and reset it etc and has still done nothing. I am completely stumped. Command prompt returns this when pinging...
www.facebook.com:
C:\Documents and Settings\Remmer>ping www.facebook.com
Ping request could not find host www.facebook.com. Please check the name and try again.
and the IP address:
:\Documents and Settings\Remmer>ping 69.63.184.28
Reply from 192.***.*.*: Destination net unreachable
Ping statistics for 69.63.184.28:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
I have posted this elsewhere and only got the response:
"your computer or laptop is not getting assigned proper ip address"
which is all well and good, but how do i fix this? and why is it happening?
Networking isn't really my strong area, but I work well with computers and can follow instructions.
Thanks in advance
www.facebook.com:
and the IP address:
Thanks in advance
