Help with CPU and motherboard
D2jsp
My friend gave me a decent computer he custom build with a Nvidia graphics Card and some other expensive components.. Well I know about using computers but not to much about the hardware. The computer he gave me needs a New CPU and Motherboard. I was thinking about getting a new quad core and an ASUS motherboard.... The only thing is im not sure if everything is compatible? like i said I dont know much about the hardware..
Best of having a look and see what type of hardware you are running at the minute. Like current mobo, CPU, RAM, GCard/s, PSU wattage, case size, HDD/s and any other info you may have about the PC.
This way we can suggest new components for you to look at, this will insure that everything will work with the hardware you have installed at the min.
Also do you have a budget? This will also help us to find you the best CPU/mobo for price/performance.
