Help with First Build
foreign_kid
Heres a list of parts(not including case), I was wondering if they will work.....
CPU: AMD PhenomII x6 1055T
Motherboard: GigaByte AMD 880G/SB850 FSB 5200
RAM: ADATA 2GB DDR3-1333 LONGDIMM -- *3
Display: Sapphire HD 5550 1GB GDDR3 DVI/D-SUB/HDMI
DVD: LD GH24NS50
HDD:HITACHI HDT721032SLA360 7200RPM SATAII 320GB
Power:CORSAIR CMPSU - 750TXUK 750W
for use in Canada
Thanks
Looks good to me, but have you considered 4 gigs of RAM? That is what most systems are being built with today.
Also, is 320 gigs enough room for you? It could be, I was just wanting to make sure.
They will work.
However, I suggest you reallocate the budget between rhe components.
Video card - 5550 is a low end video card. What are you using this machine for?
PSU + Video card - With only 5550, you won't need 750W PSU. Get a cheaper 500W - 600W ($60) and save some money. The $40 you are saving can go for a better video card
CPU + RAM - Phenom IIx 6 1055T is not necessary unless you use this machine for video editing. However, if you use it for video editing, 2 GB RAM is definately not enough. I recommend you get Phenom IIx4 955, and use the extra $40 to get another 2GB RAM.
HDD - Hitachi is not my personal favourite... I usually get WD/ Seagate
what if i change the video card to
HIS HD 5770 IceQ 5 Turbo 1GB (128bit) GDDR5 PCIe
can i still get a cheaper PSU?
and for the RAM part, i was thinking of getting 3 of that 2GB
for the HDD, i have 3 different external HD's, 1TB, 500GB, 250GB, thats why i don't need that much, what about
Seagate ST3250318ASBOX
thanks
thanks
HIS HD 5770 IceQ 5 is good, where are you buying from? you would find 5770 starting from $130 at newegg
PSU - 500 - 600W would run single 5770 without problem.
RAM - sorry, I missed your *3. amd running dual channel not triple, so either 2 x 2GB or 4 x 2GB or 2 x 4GB
HDD - is it OEM or retail version? just get OEM, your motherboard come with cable
