Help With First Build
elock37
Hi guys,
I was on here last month and I had a build all put together but decided to wait. I've come up with another $600 ($1,800 budget now) and I want some advice as to where to put this money. I want this to be a powerhouse, but not solely a gaming machine.
Anyway, here's my ideas:
Antec 900 Two + G.Skill 4GB (2x2GB) Ripjaw Series - $192.94
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.469345
Intel Core i7-960 Bloomfield 3.2Ghz + EVGA X58 FTW3 Mobo - $804.99
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.459228
SeaSonic X650 80Plus Gold Modular PSU + Western Digital Caviar Black 1TB 6.0Gb/s SATA - $199.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.477113
EVGA GTX 470 + PLEXTOR Black BD Combo Drive - $414.98
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.477281
Windows 7 Home Premium Full - $180.93
http://www.newegg.com/Product/Product.aspx?Item=N82E16832116716
Total With Shipping: $1,808.64
So I have some questions:
Is everything compatible?
Will it all fit?
Will it run cool enough?
Is Windows 7 64-bit OEM okay?
Is the PLEXTOR OEM drive okay (will I be able to play and write Blu-Ray out of the box)?
Last but not least, any changes or suggestions are very much appreciated.
Speaking of overclocking, could you link me a an article on it? I have no idea on how to do that and if I'm gonna get the 930 I would definitely like to.
Am I going to need to get an aftermarket heatsink or other way to cool it?
Yes if you have the money then why not get an SSD. have a look on newegg, try to stick to ones with the "sandforce" controller.
Alright, looks like I'll definitely be investing in an SSD. If I'm going to be overclocking is there any extra cooling I'll need?
out of all of these which one would you recommend the most? Also what's the difference between the two ocz's?
Vertex uses Samsung memory, Agility uses Micron memory. The G.skill would be my drive of choice of those due to their great support and the price.
After looking around at other posts and Googling the price cuts on the i7-950, I think I'm going to pick that up when it drops to $294. I have less of a chance of screwing that up than overclocking a 930.
Source:
http://files.shareholder.com/downlo...129/Aug_8-15-22_and_29_combined_1ku_Price.pdf
Overclocking is pretty hard to screw up, at or near stock voltages if your chip is anywhere near decent you should be able to hit ~3.4Ghz.
