wellhellothere
Couple of minor problems i'm having with a pc im fixing. Primarly, the main problem was the PC was shutting down automatically - i solved this using the 'shutdown -a' fix. I rebooted the machine to find that the taskbar has hidden itself.
I've not come across this problem before - explorer.exe is running so its not the obvious...
I suspect a virus, so im trying to copy malware bytes from one machine to the faulty machine in question, which leads me to my next problem - the machine wont recognise the USB stick. I've tried microsofts fixes (deleting upper and lower filters from the registry, but to no luck).
Any help with these problems would be great! Thanks
