Julian New Member Jan 3, 2012 #1 I have this computer. HP a6807c Click ^^ for PC specs. :3 Are these parts compatible with the a6807c? Nvidia 9800gtx 1gb. Q6600 2.4GHz 500 Coolmaster Watt's And if any better parts that you know of that are under the budget of 350$, please list them. ^^
H HazzaHnoob New Member Jan 4, 2012 #2 Yeah, that should all work fine in your current PC, as long as there's space for the graphics card...
claptonman New Member Jan 4, 2012 #4 Yes, it says: 1 PCI x16 slot for graphics card Where are you buying your parts? You can get a E6600 for cheap on ebay. $95 http://www.ebay.com/itm/INTEL-CORE-...3285?pt=CPUs&hash=item4ab29759d5#ht_718wt_934 $59 or $39 with rebate http://www.newegg.com/Product/Product.aspx?Item=N82E16817207018 GPU option 1 - AMD 6870 $170 - $200 with rebate http://www.newegg.com/Product/Product.aspx?Item=N82E16814125357 http://www.newegg.com/Product/Product.aspx?Item=N82E16814102924 GPU option 2 - Nvidia 560 $180 - $200 with rebate http://www.newegg.com/Product/Product.aspx?Item=N82E16814127593 http://www.newegg.com/Product/Product.aspx?Item=N82E16814127592 http://www.newegg.com/Product/Product.aspx?Item=N82E16814121446 Total: $304 - $354 Those would get you much, much better performance than the parts you chose.
Julian New Member Jan 4, 2012 #5 Q6600 haha :3 not e6600. And is the GTX 560 compatible w/ my motherboard to? Just wanna make sure.
claptonman New Member Jan 4, 2012 #6 Oh, whoops. I said E6600 but the Ebay link is a Q6600. And yes, a x16 PCI 2.0 is plenty for any graphics card out there today.
