What do you think to this for my first build? I'm looking for a low cost build that will do general computing, a bit of photoshop and will play The Sims 3 with expansion packs on high settings. I'm pretty sure the graphics card will do it and all the other specs are ok but because of my inexperience I'm not sure if everything I've picked is compatible or if I've made any silly mistakes. Any advice you could give me would be really welcome.
Here's a link to my basket.
Thanks.
Doh. I forgot to put the graphics card in the basket. It's here.
Thanks.
