Painkiller
I have had a problem where when I try to open and run a program, one that is already installed and everything, that it will not bring up the screen it should so I can operate the program. I have two programs that I have found that do it, OurTunes and DVD X Copy Platinum. DVD copy used to open and run fine but now for some reason it won't, it acutally brings up a little picture thing on it like it always has, then after that the entire program loads, but now it just goes away and nothing comes up. The weird thing is that under processes on my task manager it shows these programs as running. What can i do to be able to use and access these programs?
