My old P5N32-SLI premium mobo took a dump and its out of warranty now so i want to piece together another rig.
so here are my thoughts so far:
Motherboard - MSI 890FXA-GD70
http://www.newegg.com/Product/Produ...&cm_re=msi_890fxa-gd70-_-13-130-274-_-Product
I was debating between this and the ASUS crosshair IV Formula.
Reason for choosing the MSI? price mostly, but also to try something other than ASUS
CPU - AMD Phenom II X6 1090T black
http://www.newegg.com/Product/Produ...849&cm_re=phenom_ii_x6-_-19-103-849-_-Product
Ram - G. Skill Ripjaws 6gb (3x2gb) DDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231304&cm_re=ripjaw-_-20-231-304-_-Product
Now i plan on using some of my old stuff still from my old rig for the time being (budget right now).
-1 CD/DVD drive
-1 CD drive
-Thermaltake Toughpower PSU - 700W
-My old Western Dig WD1600 160gb hardrive
-piece of crap radeon X700pro
Few things im wondering about.
-First of all, I will be wanting to upgrade the GPU when budget allows. so im wondering what a good route to go is. I would like to hook up this rig to a flat screen TV eventually and use it for gaming.
was thinking of this
Second, my PSU "should" be more than enough to run this effectively, right?
Third, I currently have a Cooler Master CPU cooler found here. from what im reading it wont work with an AM3 socket. If it does, will this be efficient enough? otherwise i will be looking into a self contained water unit, but definitely open to suggestions on other heatsinks/coolers.
Final thing i would like to complete this is a set of hard drives. from what i understand a smaller solid state drive is preferred for the main drive and a larger drive used for storage.
is this correct, and what are some decent drives for this?
Currently ive been using a WD 2tb external for all my storage on my laptop
Thanks for taking the time to read this if you actually got this far.
I really appreciate any feedback or suggestions any of you may have
-1 CD/DVD drive
-1 CD drive
