Hey guys i am new at this stuff. I am not very knowledgable. but this is my build. can you tell me if everything is supported?
Mobo + Cd Drive http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.467597
Processor http://www.newegg.com/Product/Product.aspx?Item=N82E16819103843
Ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820141300
Case + PSU http://www.newegg.com/Product/Product.aspx?Item=N82E16811147082
HDD http://www.newegg.com/Product/Product.aspx?Item=N82E16822148451
So can you tell me if everything is supported with motherboard and the case everything?
Can i run it without a graphic card it has onboard Radeon 4200 HD? so i dont need Graphic card i can buy it later right? i am just a casual gamer not much...
Also are 2 Fans good enough for this kind of this PC
Its $250 dollars when i add everything and that my budget is it a good deal? thanx please reply
