This will be my first time building a computer and i have assembeled a list of parts, if someone with a little more expierence could critic it that would be great. By the way my comp now is only a 384Mhz so this will be a step up haha, are all the parts i listed compatable. Thanks
Nick
Turkey Day Blow Out!
Aspire X-Dreamer II(Black) ATX Mid-Tower Case with 350W Power Supply, With Window, Model "ATXB4KLW-BK/350"
Model# ATXB4KLW-BK/350W Item # N82E16811144026
Specifications:
Case Type: Mid-Tower
Color: Black
Material: Steel
Drive Bays: 5.25" x 4,3.5"(External) x 2, 3.5"(Internal) x 4
Expansion Slots: 7
Front Ports: USB2.0 x 2,Mic x 1,Speaker x 1
Power Supply: 350W
Cooling System: 2 x 80MM fans
Motherboard Compatibility: ATX/Baby AT
Dimensions: 440 x 200 x 430mm
Special Features: Acrylic added to front panel for polished appearance;Back lighting temperature displasy LCD etc
49.00
Aopen 16X Double Layer DVD+/- RW Black Burner, Model DUW1608, OEM
Model# 91.4ID37.004 Item # N82E16827140115
Specifications:
Write Speed: 2.4x DVD+R DL (Double Layer), 16x DVD+R, 4x DVD+RW, 8x DVD-R, 4x DVD-RW, 48x CD-R, 32x CD-RW
Read Speed: 48x CD-ROM, 16x DVD-ROM
Interface: ATAPI / E-IDE
Buffer: 2MB
OS Support: Windows XP/ 2000/ ME/ 98SE
Features: JustLink Buffer Underrun Errors Prevention Technology, Dynamic Damping System (DDS) to reduce vibration/noise, JustSpeed technology for adaptive writing speeds.
Packaging: OEM (see pictures for details)
67.99
Samsung Black 52X CD-ROM, Model SH-152AEBUB, OEM
Model# SH-152AEBUB Item # N82E16827151046
Specifications:
Read Speed: 52X Max CD-ROM
Interface: E-IDE/ATAPI
Buffer: 128KB
Access Time: 80 ms
Data Transfer Rate: 7800KB/sec
Supported Disc: CD-R/RW,CD-DA,CD-ROM/XA,Video-CD,CD-I, Multisession Photo CD,CD-EXTRA
17.99
SAMSUNG 160GB 7200RPM IDE Hard Drive, Model SP1604N, OEM Drive Only
Model# SP1604N Item # N82E16822152011
Specifications:
Capacity: 160GB
Average Seek Time: 8.9 ms
Buffer: 2MB
Rotational Speed: 7200 RPM
Interface: IDE ULTRA ATA133
Features: Fluid Dynamic Bearing Spindle Motor Technology
Manufacturer Warranty: 3 years
Packaging: OEM Drive Only
84.00
Corsair Value Select 184 Pin 512MB DDR PC-2700 - OEM
Model# VS512MB333 Item # N82E16820145407 Specifications:
Manufacturer: Corsair
Speed: DDR333(PC2700)
Type: 184 Pin DDR SDRAM
Error Checking: Non-ECC
Registered/Unbuffered: Unbuffered
Cas Latency: 2.5
Support Voltage: 2.5V
Bandwidth: 2.7GB/s
Organization: 64M x 64 -Bit
Warranty: Lifetime
82.00
ASUS "P4S800" SiS648FX Chipset Motherboard for Intel Socket 478 CPU -RETAIL
Model# P4S800 Item # N82E16813131462
Specifications:
Supported CPU: Intel Pentium 4(HT)/Celeron Processors
Chipset: SiS 648FX + SiS 963L
FSB: 800/533/400MHz
RAM: 3x DIMM support DDR400/333/266/200 Max 3GB(2x DIMM for DDR400/333 only)
IDE: 2x UltraDMA 133 up to 4 Devices
Slots: 1x AGP 8X, 5x PCI, 1 x Wi-Fi
Ports: 2xPS2,1xCOM,1xLPT,SPDIF Out,6xUSB2.0(Rear 4),1xLAN,Audio Ports
Onboard Audio: AD1980 6-Channel Codec
Onboard LAN: 10/100Mbps Fast Ethernet
Form Factor: ATX
68.00
Intel Pentium 4/ 3.0E GHz 800MHz FSB, 1MB L2 Cache, Hyper Threading Technology - Retail
Model# BX80546PG3000E Item # N82E16819116171 Specifications:
Model: Intel Pentium 4 w/ Hyper Threading
Core: Prescott
Operating Frequency: 3.0GHz
FSB: 800MHz
Specifications:
Core: Prescott
FSB: 800MHz
Cache: L1/12K+16K; L2/1MB
Voltage: 1.25V - 1.525V
Process: 0.09Micron
Socket: Socket 478
Warranty: 3-year MFG
187.00
Rosewill nVIDIA GeForce FX5200 Video Card, 256MB DDR, 128-Bit, DVI/TV-Out, 8X AGP, Model "RW5200-256D" -RETAIL
Model# RW5200-256D Item # N82E16814164014
Specifications:
Chipset/Core Speed: nVIDIA GeForce FX5200/250MHz
Memory/Effective Speed: 256MB DDR/400MHz
BUS: AGP 4X/8X
Ports: VGA Out(15 Pin D-Sub) + TV-Out (S-Video) + DVI
Support 3D API: DirectX 9, OpenGL 1.4
Max Resolution@32bit Color: 2048X1536@60Hz
Cable/Accessories: Manual, S-Video Cable, Driver CD
Retail Box (See pics for details)
79.00
Nick
Specifications:
Color: Black
Material: Steel
Expansion Slots: 7
Power Supply: 350W
49.00
Specifications:
Buffer: 2MB
67.99
Specifications:
Buffer: 128KB
Access Time: 80 ms
17.99
Specifications:
Capacity: 160GB
Buffer: 2MB
84.00
Cas Latency: 2.5
Bandwidth: 2.7GB/s
Warranty: Lifetime
82.00
Specifications:
FSB: 800/533/400MHz
Form Factor: ATX
68.00
Core: Prescott
FSB: 800MHz
Specifications:
Core: Prescott
FSB: 800MHz
Process: 0.09Micron
Socket: Socket 478
187.00
Specifications:
BUS: AGP 4X/8X
79.00
