mccoyboy22
ok so heres my setup, i would like to know how much power from my psu i need, this is the only thing ive never understood about building a computer, i have tried 2 different calculators but i want to be on the safe side and get a second opinion.
NZXT Phantom PHAN-001RD Red Steel / Plastic ATX Full Tower Computer Case
WD BLACK SERIES WD2003FZEX 2TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236624
EVGA G-SYNC Support GeForce GTX 770 DUAL SuperClocked 4GB 256-bit GDDR5 PCI Express 3.0 SLI Support Video Card 04G-P4-3774-KR
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130945
G.SKILL Trident X Series 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 2400 (PC3 19200) Desktop Memory Model F3-2400C10D-16GTX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231589
MSI Z97-Gaming 7 LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130768
Intel Core i7-4790K Haswell Quad-Core 4.0GHz LGA 1150 Desktop Processor BX80646I74790K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117369
DEEPCOOL GAMMAXX 400 CPU Cooler 4 Heatpipes 120mm PWM Fan with Blue LED
http://www.newegg.com/Product/Product.aspx?Item=N82E16835856005
Kingston SSDNow V300 Series SV300S37A/120G 2.5" 120GB SATA III Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820721107
Also if you have any tips or ideas im completely open to them.
