HP Office Jet 7740 Pro - Supply system problem with replacement cartridge
petar0001
HI, I have an HP OfficeJet 7740 Pro. After using expensive original ink cartridges I switched to Orink replacement cartridges. The printer detected that they weren't original. I did some research online and found a file that allowed me to downgrade the firmware to an older version, 1849A. That worked! About 10 months later, I got an error regarding the cyan cartridge; it shows as empty, even though the others are at about 20% (so I assume the cyan one should be, too). I bought four new third-party cartridges—Orink again—but received the error: "There is a problem with the supply system. Try replacing the affected cartridge with a different, non-empty cartridge. If the message reappears, record the message and contact HP." I tried inserting the old, depleted original cartridges; the printer correctly identified them as "depleted" and prompted me to replace them with new original ones. I replaced the four Orink cartridges with another set of new Orink cartridges, but the problem persisted. I then bought a different brand of third-party cartridges—the seller claimed the chips were updated for newer firmware—so I gave those a try. As soon as I inserted them, the printer showed full levels for all four colors, and I thought the issue was resolved. However, after the printer finished its initialization process, the "supply system problem" error appeared again. I removed the printhead; it looks fine, as do the connectors—no signs of corrosion or wear—and I don't see any paper stuck inside. I tried downgrading the firmware again, but that didn't help. The only difference I notice during the downgrade process is the printer status: while all the manuals indicate a "Ready" status, mine shows "Busy." And there are no leftover files in the print queue.This has driven me crazy; I hate to just throw it away without putting up a bit more of a fight. Does anyone know—or have any suggestions on—what I can do to get it working?Thanks
Unfortunately, HP is one of the companies that really want you to use their own ink instead of generic brands. It really doesn't matter what generic brand you use. Downgrading the firmware probably isn't gonna help much either as you have seen already. My only suggestion is to buy a different brand of printer or pay the full price for HP ink. I"ll never recommend HP products. The printer itself is already 10 years old.
