thxEmpty the recycle bin. Hate to say it but 120gb is way too small for a single drive system. You should get a 500gb SSD if possible and clone to the new drive. You can also download and run windirstat to see what is taking up all the space.
Then post the image it displays once its done calculating, it will take a minute to complete. View attachment 10566
i already have a 1 tb hard drive i use for everythingYou might claw back 8-16G or so by deleting the hibernation file if you don't use that feature. It would be equal to the amount of RAM in your system.
Command Prompt as admin -> powercfg -h off
Otherwise install less crap to your drive, install to a different drive, or get a larger drive. Per above you can use Windirstat to see what all is utilizing that space. If you continue to see gigabytes consumed for no perceptible reason it might be worth doing a malware scan like with Malwarebytes.
What does your other drive look like?
Clearly not everythingi already have a 1 tb hard drive i use for everything
