I have and odd problem with a new PC
When you put the card in did you check the bios setting to make the onboard sound was disabled? How about in both pci slots? If the onboard was left enabled you won't hear anything through the expansion card. That would have to be disabled first. If you still didn't hear anything after Windows detects the new hardware and installs the drivers that would point towards a board problem then. :confused:
You're certainly having a field day with that one! :mad: is probably the expression right about now. I am slightly suspicious that a bios update maybe needed or a board driver isn't in quite fully where the pci bus is seeing a problem there. The last idea would be a board fault. Review the user's manual for Plug'n'Play and OS2 support settings in the bios.
well, I am not to worried about it all, this thing sound fine, so I think I am going to keep it the way it is
