I lost my Asus cd,Help me,I need to intstall the sound completely,I have no sound!
Kiwi^
Well hello! :)
I can't hear any sound on my computer, Windows says that it found a new hardware, but when I try to install the "Multimedia Audio Countroller" It wont complete the install, and I have no sound. :mad:
Audio information:
ADI AD1980 SoundMax 6-channel audio CODEC support for S/PDIFout interface. :D
That's all I know about my sound ("card?").
I have p4v8x-x Motherboard(Asus) system or something.
if anyone know what I gotta do to fix this, please help me, or if anyone could send me the Asus cd for that sound ("card?") please send me! :) because it worked good, when I had the cd.(Damn I should never have formated my computer whitout checking I had the cd).
You guys just think I'm gonna fix this whit finding my cd again, but I can't I've been whitout sound for 3 months! I'm desperate!!!!!!!
thanks!
http://usa.asus.com/products.aspx?l1=3&l2=12&l3=52&model=211&modelmenu=1
is this your motherboard?
then here are the drivers to download.
http://support.asus.com/download/download.aspx?SLanguage=en-us&model=P4V8X-X
you might want to download them all, and burn them on a CD, so you have a backup ( in case they remove them from the site )
Thanks!
But I don't know what to do whit the file, it's on 0.5 mb, how can i install something from a rom file btw?
Well thanks for trying, and yes, it's my p4v8x-x u got on that picture :D
you have to click the Drivers tab first. then its the 2nd one counted from above.
(it says "SoundMAX Audio Driver version 5.12.01.3663 WHQL driver for Windows 98SE,ME,2000,XP" )
the ROM files, are bios updates, you dont need those :)
Thank! I got my SOUND BACK!
And i downlaod all the drivers, I'm so glad atm.. :D
Thanks you guys, for taking time to help me! :)
KEEP THIS SIDE ALIVE! :D
<<^^~~Hail www.computerforum.com~~^^>>
