I need a good antenna for my wireless card. There are lots on antennas advertised but I have not idea which ones work the best. Sometimes in a motel I am out of range and can not use the computer in my room. It is a PCI card.
What kind of card is it? If it's PCMCIA you most likely can't find an extension antenna. I would recommend getting a wireless N card, they have much higher bandwidth and range..
