I need help!!!!
Dreja15
i took a thing and opened it with abobe reader just to see if the programm works and then everythin is opening with abobe reader only way to open things at the right way is to go in to program files and open them there pleas help me!!! :eek: (i have windows 7)
I think if you right-click and press Open-With... and then single-click the program you want to open it with, you have the choice to check some box where it says "Always Open these files with this..."
