Installed Slave Hard Drive( Help! )
MrDave3D
I added a Slave hard drive.
Got it all hooked up and went to start up,It say's press Shift-F10
Pushed them all together and seperatly but nothing happened and went booted and went back to same thing again etc...
Need help what do i do.
Did you change BIOS or the actual physical HDD Settings to keep the first drive as Master?
Also, FWIW, you might consider changing your Sig. It could be construed as offensive.
