dznutz New Member May 3, 2009 #21 has the burner been verified working on another pc? if so then i'd run a repair using your windows cd
S stirling New Member Jun 1, 2009 #22 Yes.. trying on other pc is best solution to find which one is broken, is it the os or the hardware
StrangleHold Moderator Staff member Jun 1, 2009 #23 Sounds like to me that you keep hooking up two drives on the same cable with both set as Master or Slave. Will not work!
