Just Installed A Diamond Xtreme Sound Card On XP No Sound
DJboutit
I just installed a Diamond Xtreme 5.1 sound on a computer with windows xp drives installed just fine but I get no sound when I try to play anything any ideas what could be wrong??
johnb35
Administrator
Check your playback sounds and make sure it set correctly. Also, make sure your audio cable is plugged into the green port on the sound card.
DJboutit
I fixed problem with the sound card I deleted the driver that came with the cd and ran Driver Fixer it found a driver and installed. I also had to disable and deleted a USB sound card driver these two things fixed my problem Now I am getting audio playback from the Diamond Xtreme.
johnb35
Administrator
Be careful about those driver update programs as they are usually malware or include malware in with them. You always want to get the latest driver directly from the manufacturer anyway.
