cowboyspc94
Help my laptop freezes. LIke all of a sudden it freezes and wont turn off even if i press the plug. I must hold the on/off button for like 15 seconds. And than when i restart it the sound is gone. It doesnt work not even volume control or it freezes when it starts. It freezes if type too fast or move suddenly or tap it. It froze when i was making this thread so i gad to rewrite it. And it always does disk checking for consistency. Help when its normal its ok but when it freezes or there is no sound.
The other laptop is normal except it turns itself off because it overheats. THe cpu fan is broken or something but i dont know how to change or fix it. And whats the price. It turned itself off yestrday saying battery was out and turned itself off. ANd hasnt turned on yet. The light where it is green is orange. ANd when i turn it on it says failure to turn on try again or something. SO i must press the on/off button again to move out. Oh yeah the sound on it works but on certain players like real player and windows media its very echoy and bad. Vlc media works perfectly the sound and winamp is ok.
If you can help thanks.
