LED Fans????
Hello,
I've recently rebuilt my pc and decided to get a 3 pack of Fractal Design Prisma AL-14 LED PWM fans. The mobo is a ASUS ROG STRIX B450-F GAMING.
Originally I thought I could connect the fans to the RGB HEADER(S) and control them all using AURARA sync
BUT I've since learned that those RGB Headers are 12 V and only for LED strips.
So, how on earth can I connect my fans up so I can control the fancy schmancy led's???
Is the a 5V header on the mobo I've missed?
It's not that the headers on your motherboard are for strips (although your motherboard manual states they are); there are two types of RGB connectors:
4-pin 12 volt
3-pin digital 5-volt/ 12-volt
Your motherboard utilizes 4-pin headers and your fans utilize 3-pin connectors. You'll have to purchase a 3-pin control module for your fans. There may be a 4-pin to 3-pin convertor for the motherboard but I'm unsure. 3-pin digital RGB is also known as addressable RGB.
We're dealing with this at work right now because the 3-pin fans we purchased don't state whether they're 5-volt or 12-volt LED. It's a mess, especially considering if you reverse a 4-pin RGB connector it will damage the LEDs.
Ok, gotcha. My fans are 4 pin 12 V and the LEDS on the fan are 5V which plugs into a 4 pin slot but there are only 3 pins. It looks like I can daisy chain them together too.
Looks like I need a controller.
However, i also want to add a few LED Strips, which would go directly into the mobo 12 V headers.
But, can I control the fans (which are connected to a controller) and the LED Strips via the built in Aura Sync?
Really want to avoid two control systems and I assumed by buying this mobo that everything could just connect there and done.
No, the AL-14 fans you purchased will not plug into a 12 volt 4-pin RGB header. They will only plug into a 5 volt 3-pin digital (addressable) header, which your motherboard does not have.
Unfortunately, no. You could purchase the Corsair Commander Pro which controls all LEDs (4-pin or 3-pin) via the Corsair iCue software, but it's pricey. There may be other LED control boxes but I can't speak to their functionality or compatibility.
Yeah unfortunately your motherboard does not utilize the necessary headers to control your fans RGB. Pricier motherboards can utilize both RGB variants.
