Its simple thermal dynamis. I learned the freezer trick from a data recovery guy. It works sometimes when you have a bad logic board on the HD. If its mechanical problems you are having, the freezer trick doesn't work as often.
I have a notion that some data recovery software recovers the data even if it is not detected by the BIOS . Search on the google "disk recovery" or hard disk recovery". Hope you will get some good one.
Its understood that all the Id cable are plugged properly and jumpers are set properly even though sometime hard drive is not detected by the BIOS.
I have faced such situation once.
