Modular Power supply, Which Cable do I need?!!!
Discussion in 'Computer Cases, Power Supplies and Cooling' started by ANNR, Jan 28, 2020.
  1. ANNR
    ANNR Active Member
    1,180
    I have this power supply, CORSAIR HX 750w POWER SUPPLY PN: CMPSU-750HX
    And I just purchased this video card: ZOTAC GeForce GTX 480
    The picture shows there are two power ports.
    Here is the problem. I can't find any cable that has those two power ports from my power supply.
    What Power cable do I need to buy for my power supply that will power the video card? Is it one cable with both plug for the video card or do I need to buy two cable for the video card?
    Thank you
  2. johnb35
    johnb35 Administrator Staff Member
    42,139
    According to the specs of that unit, it already comes with cables. And since its a modular power supply they are most likely still the power supply box if your previous setup didn't include a video card that required a power connector.
  3. beers
    beers Moderator Staff Member
    8,495
    Why? That card's 10 years old.
    As per John the PSU should have come with at least 2x PCIe cables which would facilitate what you're doing.
  4. ANNR
    ANNR Active Member
    1,180
    Thanks guys for your reply.
    Will this work? I only have one pcie cable 8pin. it can connect to the 8pin on the cable and split at the other end 2 x 2+6pin.
    I got the card second hand and it was cheap. I only needed something that can play ragnarok online.
    the psu I have did come with many cables but I have lost all of them.
    can you help me find the right cable so I can hookup the gpu?
    thank you
Share This Page
