dang
how hard is it to replace case fans that come with cases?
they are in there pretty tight, is it just a matter of screwing and unscrewing?
Agreed, since most motherboards dont have enough 3-pin plugs for all your case fans.or you can just buy a fan controller, which is cheaper than replacing all your fans.
i have to stick a sticker on the CPU with a wire attached to the sticker?
