So my new PC just arrived and i set it up and connected the pc to the monitor using an hdmi cable. It worked fine at first but for some reason now a box has appeared around the sides of the screen. Any ideas what is causing this?
if you would be referring to the AMD catalyst software i have been advised to install it however i keep getting an error message telling me installation failed because it failed to load detection driver
