Motherboard problem?
orthopaedic
Dear friends,
I am a new member in the forum and I have a technical question:
My sockett 939 computer with athlon 64x2 proccesor was working perfectly well for 6 months and suddenly is unable to start the windows and is restarding again and again. I enter bios and found that it had changed the boot priority hard disk drive by itself. I reset the bios and put the correct disk priority for booting and it started windows but could not "see" the other HDDs What could be the reason of my technical problem? (I have already checked the other (I have total 3) hard disk drives and found them healthy.
Is the problem a motherboard problem???
i say it would be. Maybe you've got a virus(I might be wrong) but try and format your hard drive and re-install windows. Might work
