motherboard solder problem
elobire
I was replacing the power jack on my laptop when i must have accidentally melted solder onto the motherboard. I'm not sure how it happened as i didnt notice it until later.
Is there any way i could remove this solder without damaging the motherboard at all and would it still work afterwards?
Thanks
Okedokey
Well-Known Member
You'd have to use a solder sucker and then resolder the connections. Not easy. Pretty sure you've buggered it.
elobire
Thanks for the reply. Luckily i managed to pull the solder off without damaging the connections underneath and the laptop works fine now :)
