Hi. I need your help guys. My computer will not come out of power save mode. I was chatting with someone on MSN and my computer's light went from blue to orange and my screen went black and I got the message "power save mode, press any key or move the mouse to exit." I pressed all the keys and moved the mouse but it wouldn't exit power save mode. I unplugged my computer and I even switched around the RAM cards. I took out the CMOS battery and tried it. Nothing worked. I also took out my video and my graphics driver cables. It still does not work after I put everything back in place [except the battery]. I recently put the battery back in and it still dosen't work. I dusted my hardware inside my computer and cleaned the fans. There's this orange light on inside my computer as soon as i put the power cable in the back of my pc. I don't know what to do. This is so frustrating. I need your help! Here are some pictures of my computer[Dell Inspiron 530s A].
1: http://tinypic.com/r/28vwufp/7
2: http://tinypic.com/r/dwvzhz/7
3: http://tinypic.com/r/1444ojt/7
Here are the coressponding parts to the numbers of picture 3:
1 - processor socket (CPU)
2 - processor fan connector (CPU_FAN)
3 - memory module connectors (DIMM_1)
4 - memory module connectors (DIMM_2)
5 - memory module connectors (DIMM_3)
6 - memory module connectors (DIMM_4)
7 - main power connector (ATX_POWER)
8 - battery socket
9 - serial ATA drive connectors (SATA0)
10 - CMOS jumper (CLEAR CMOS)
11 - password jumper (CLEAR_PW)
12 - serial ATA drive connectors (SATA1)
13 - serial ATA drive connectors (SATA4)
14 - front panel connector (F_PANEL)
15 - front USB connector (F_USB1)
16 - serial ATA drive connectors (SATA5)
17 - front USB connector (F_USB2)
18 - front FlexBay connector (F_USB3)
19 - front audio (F_AUDIO)
20 - PCI connector (PCI2)
21 - PCI connector (PCI1)
22 - PCI Express x1 connector (PCIE_X1)
23 - PCI Express x16 connector (PCIE_X16)
24 - audio connectors
25 - 2 USB and 1 LAN connector
26 - 2 USB connectors
27 - chassis fan connector (CHASSIS_FAN)
28 - video connector (VGA)
29 - power for cpu (ATX_CPU)
thankyou for your help in advance!
8 - battery socket
