My first build, please comment
Better, will you upgrade to 4GB later... and i might have missed it, but what is your OS going to be, vista?
Agree
I know this is has kinda turned into a tri-core discussion but I just thought I would let everyone know that I ordered the stuff, but it looks a little different, here are the changes:
mobo and processor are different:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131178
I cracked and got the DVD/CD Burner also. These changes actually allowed me to cut about $120 off (before rebates:P) my $800 budget because that mobo has a built in video card and should support everything that I will use. Thanks for everyone's input.
Eh... I would've gone with the P35-S3G personally... That motherboard isn't the best... Hopefully the memory you ordered is compatible with it... not in speed, but as in brand and model. Asus is picky about RAM...
That is GREAT but you should get a CD/DVD burner Here is one for $16.99
1) No combo burner will be that cheap...
2) It's a CD burner, and no more...
3) It's not SATAII...
