My first build, please help.
TheQuiff
Hello im gooing to be buying all these computer components and build the pc myself. I have never done this before i have read manuels and i have read articles aswell. I done what of my own knowledge of all the components to make sure they fit. I am not 100% sure of this so could someone be helpfull enough to check and see if these fit please.
Asus P8P67 Pro R3 P67 Socket 1155 8 Channel HD Audio ATX Motherboard
Intel Core i5 2500K 3.3GHz Socket 1155 6MB Cache Retail Boxed Processor
Corsair 4GB (2x2GB) DDR3 1600MHz/PC3-12800 XMS3 i5 Memory Kit CL9(9-9-9-24) 1.65V
Gigabyte GTX 560Ti OC 1GB GDDR5 Dual DVI Mini HDMI Out PCI-E Graphics Card
CM Storm Scout Case - 120mm and 2x 140mm Fans Included
Corsair TX 650W V2 PSU - 80plus Bronze Certified
Samsung SH-S222AB 22x DVD±RW DL & RAM SATA Optical Drive - OEM Black
Any help is much appreciated
It'd be better to post links to it using newegg or some other site so we can see the details.
As long as your RAM is the correct speed for the MoBo, you're good to go. I'd recommend an aftermarket CPU cooler if you're doing any overclocking, but that's just me.
Ahh thanks, ill look into hd 6950 what resolution is it btw? Does the case matter will it fit right into the case? If i wanted to get a bigger case in the future will that MoBo fit in nearly all cases?
Most new cards are gonna be 2560 x 1600, which is more than enough.
Your case is big enough to fit your MoBo and GPU in.
ATX MoBo = ATX case
ATX is pretty much the standard nowadays. You should be fine. But with a Midcase, you may have limited space for all the cables, but it will still work. You could get a full tower, but they are expensive.
Ahh thanks. Well my orginal budget was £500 that went out of the window, now its £810 :( soo i hope i can afford all these :) Thanks for the help
