Need help building a PC
Kal-El
Hello guys,
I need a computer and would like to know what you guys would recommend. I'll be creating/editing videos, will also use photoshop/premiere pro cs6 along with other editing programs, downloading/uploading content on the net, multitasking. What build would you suggest (please include links if possible), budget is roughly $2500 to $3000.
By the way, I was curious about this tower: CORSAIR - Crystal Series 570X RGB ATX Mid-Tower Case, but I'm concerned about dust and cleaning it, is it really practical or is there something else out there that would be better?
Thanks in advance.
Cisco001
Well-Known Member
how about this?
Personally think 570X too expensive...
460X cheaper, plus you only clean 2 sides of glasses?
PCPartPicker part list / Price breakdown by merchant
CPU: Intel - Core i7-7820X 3.6GHz 8-Core Processor ($568.89 @ OutletPC)
CPU Cooler: CRYORIG - H5 Ultimate 76.0 CFM CPU Cooler ($46.88 @ OutletPC)
Motherboard: Asus - TUF X299 MARK 2 ATX LGA2066 Motherboard ($248.49 @ SuperBiiz)
Memory: G.Skill - Ripjaws V Series 64GB (4 x 16GB) DDR4-3200 Memory ($806.99 @ Newegg)
Storage: Samsung - 960 EVO 500GB M.2-2280 Solid State Drive ($229.99 @ B&H)
Storage: Western Digital - Red 3TB 3.5" 5400RPM Internal Hard Drive ($105.49 @ OutletPC)
Video Card: MSI - GeForce GTX 1080 8GB Video Card ($542.03 @ Amazon)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case ($122.99 @ Best Buy)
Power Supply: EVGA - SuperNOVA G3 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($122.79 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($89.89 @ OutletPC)
Total: $2884.43
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2018-01-03 07:16 EST-0500
_Kyle_
Well-Known Member
The 570x is pretty impractical. Look at a case with one glass side panel if you want to see the inside. The Fractal Design Meshify C is one of my favs.
Cisco001
Well-Known Member
Due to the unknown on latest intel bug.
Here is the AMD alternative you may consider...
CPU: AMD - Ryzen 7 1800X 3.6GHz 8-Core Processor ($379.99 @ Amazon)
Motherboard: Gigabyte - GA-AX370-Gaming K5 ATX AM4 Motherboard ($165.38 @ OutletPC)
Case: Corsair - Crystal 460X RGB ATX Mid Tower Case ($133.99 @ Best Buy)
Total: $2623.42
Generated by PCPartPicker 2018-01-03 11:56 EST-0500
